LCD problem after changing ssd - help to narrow down symptoms?
Hi there.
After following different tutorials here, I decided to upgrade my iMac 27" late 2013 with a new SSD. But, unfortunately, when mounted the display assembly back the image is scrambled - I can barely see anything.
- Backlight is good
- Connecting an external monitor shows the image properly
- Changed LVDS cable and shows the same thing. But, weirdly, after changing and reseating the cable once or twice, image appeared, and after a restart, disappeared again.
- Cleared PRAM, and all sort of stuff
I believe it might be the display assembly, but just wanted to ask if someone had this issue previously, just to make sure I don't buy a new display assembly and then figure later on the problem is the motherboard. Below is a picture of what I'm seeing:
Any thoughts?
좋은 질문 입니까?
댓글 3개
To be clear here you pulled the logic board fully out and put in the blade SSD on the back side? Or, did you just swap out the HD for a SSD?
Dan 의
Hey Dan, thanks for your answer. I just swapped my hd by a ssd - so, no chance to be it.
I didn't try putting it backwards - did the same way the original was (with the original cable, the results are the same - just garbage on screen).
Funny enough, when I keep the lcd disconnected, using an external monitor, the system gets stable and fast. When I connect it, system gets crazy and slow - but works anyway.
Will try to do it and let you know.
Tks
Robson Silva 의
Hey Dan. Just tried putting the cable in the opposite side, and I see the same image.
As I said, the way the cable is now I saw the image 3 times, and after rebooting, it didnt come back.
Robson Silva 의
