Hi,
Check, by using Device Manager, to see that you have the latest drivers for your WLAN adapter.
To get to Device manager in Win10 press win key + x key together, window should pop up with various links, including Device Manager, click to enter Device Manager, scroll down and find under Network Adapters your WLAN adapter , right click on it select Properties, click on Driver Tab update drivers.
Or here is a link to the latest Asus drivers. Use only the WiFi one if everything else is OK.
http://ivanrf.com/en/latest-asus-drivers...
How many signal bars are showing on the WiFi connection?
Are you using the 2.4GHz or 5 GHz channels to connect?
Try downloading, installing and running a free WiFi scanning program to check the WiFi.
Use the program to see the actual signal level that you are using (remember the higher the number in dB the lower the signal strength - it is in -ve values). Also check to see how many other networks are on the same channel. The more networks using the same channel the more chance of interference which can cause problems.
Here is a link to a free WiFi scanner program. It is only one of many available.
http://www.techspot.com/downloads/5936-i...
Hopefully this will be of some help.
댓글 2개
I followed all replies EVERYWHERE with this. Going to the windows update website and clearing the "hung up install" and installing the updates again is what it was for me. Who is to say it is the download failing or the install failing but I suspect it is an errant packet or two that caused a "perpetual downloading" of a VERY massive update and it just churned causing the laptop to not only lose internet connection but to run as slow as molasses. It made a nice little machine run so slow I thought it was garbage time. Nope. Thanks to all for their answers.
Pixel Artist 의
How did you do that if your interns wasn’t working? That’s my problem... I can’t update anything bc all updates are asking for internet. Can you please give me a step by step instruction list for what to do? Please email at d_wade25@yahoo.com if you or anyone has some instructions I can do without my asus having any internet... I desperately need this thing to start working now.
d_wade25 의
