T800 Battery decreasing while turned off and on charge?
Hi
I have a Samsung T800 tablet and which is having some serious trouble charging. It originally had a damaged charging port which was replaced and since then whenever its plugged in to charge the battery keeps draining even while switched off. This also happens with a new battery.
Any ideas?
Thanks in advance
좋은 질문 입니까?
댓글 3개
@hortman did it ever work properly after you repalced the charging port? Have you verified that the replacement is properly installed?
oldturkey03 의
It did work here for me when i changed it. port does seem to work properly, it shows the battery symbol when plugged in and has the little bubbles. Should I try another?
Hortman 의
So from what you are saying that it is indicating that it is charging but it is not? I would double check the connector and the connection.
oldturkey03 의
