주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
Broken home button / fingerpr. scanner iPhone 6 after replacement
Hi, i have replaced a new lcd screen to the front metal plate on my Iphone 6 , but unfortunately i damaged some of the small little plugs on the connector on the home button when i loosened it. So my question is , is it possible to loosen the broken connector on the home button and buy a new contact so the fingerprint scanner can function again. Someone who has such a guide to refer to ?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 4개
Which part of the home button connector was damaged?
The one on the board?
The one along the backplate?
The tiny piece that goes from the home button?
Please answer and I can help more.
Hi , its the connector on the home button that secured to the connector from the back flex cabel from the metal plate.
ugggh....that's the worst one!
You can easily replace it, but your fingerprint scanner will no longer work :(
Ok, than i dont think i will try do it , thanks :-)
댓글 달기
답변 2개
가장 유용한 답변
Since the home button is damaged, unfortunately, the Touch ID functionality won't work anymore, even if you replace your home button. If you do replace your home button, it will still "click" to go to the home screen still!
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Should not be overly difficult. You need to find the righ type of connector and solder it on.
The main problem is limiting heat damage. FPC and adjoining parts may not take the heat for rework. Also if you destroy it you lose it forever.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
B Tobiassen 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 91
