Not firing when trying to crank
My power washer does fire when I try and crank it
좋은 질문 입니까?
gail, trouble shooting pressure washer small engine will not fire. You will have to test the engine for fuel/air/spark/compression and see what is missing/faulty. Check the attached links,instruction and guides, Good luck
http://www.repairfaq.org/samnew/lmfaq/lm...
https://www.briggsandstratton.com/na/en_...
http://www.jackssmallengines.com/diy/tro...
해당 답변은 도움이 되었습니까?
Check Sparkplugs for loose wire, dirty connection, or debris. Spark plugs on small equipment can also break pretty easily since they are exposed.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 97
댓글 1개
gailfeltman what make and model is it? What do you mean by "washer does fire when I try and crank it"? It fires up? It comes on fire?
oldturkey03 의
