주요 콘텐츠로 건너뛰기
27" 화면 2560 x 1440 픽셀 해상도 Thunderbolt 및 MagSafe 케이블 부착물
160 질문 전체 보기
When turned off the fans keeps spinning. Is it normal?
The fans are normally very quiet but when i turn off the computer the fans of the thunderbolt display first starts spinning very fast and after 5 seconds keeps spinning not so fast but keeps running until I power on my computer again. Is it normal?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 2개
ya it normal.
Like Colonel Hogan answered is not normal, and apparently it is a common problem
댓글 달기
답변 3개
가장 유용한 답변
Hi,
have you latest Thunderbolt Firmware installed ? Check Mac Software updates. There was an update adressing fan related issues.
Update (01.10.2016)
So, now i found this about the problem.
Seems to be an apple known problem.
https://discussions.apple.com/message/16...
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Hi Colonel Hogan,
Thanks in advance for you answer.
Yes, i've already checked the updates. It is the last version of the firmware (26.2)
It is not normal right? For the thunderbolt display's fans starts when turned off.
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Have you attached external devices to the TBD ?
No, all the ports in the TBD are unused.
댓글 달기
I realize I'm incredibly late to the party here, but if you've got your MacBook charging even when it's off, the fans will cool the power adapter.
해당 답변은 도움이 되었습니까?
점수 -1
댓글 2개:
Sorry dude, Its a Thunderbolt display not a macbook that is having the problem.
yes, that's abundantly clear. in case you're unfamiliar with thunderbolt displays, they have built-in MacBook chargers. when said built-in MacBook charger is plugged into my Mac and charging, it creates heat. the fans inside my Thunderbolt Display turn on to keep the AC/DC conversion circuitry cool, even though the display itself is powered off.
thanks for giving ME a demerit for YOU not knowing what I'm talking about.
댓글 달기
귀하의 답변을 추가하세요
Kojiro Nagai 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 224
