2015년 9월 25일 출시. Model A1688/A1633. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
1892 질문 전체 보기
My home button doesn't work?
I got my screen replaced, and noticed that my home button doesn't work, yet the finger scan does.. the guy that fixed it said he could do nothing about it and that it was my problem after he charged me $260 for wrecking it on me!! . i brought it to someone else and they said that everything was still connected and that there shouldn't be any reason for it not to work... does anyone know why this might be? TIA
Update (10/02/2016)
i should probably add that the home button worked perfectly fine before the screen got fixed!
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
의견 추가하세요
맥북 배터리 수리 키트
기본 가격은 $69.99
Buy Now
맥북 배터리 수리 키트
기본 가격은 $69.99
Buy Now
4개의 답변
선택된 해법
Sounds like whoever repaired it for you was being dodgy and replaced the screen with a defective one. The home button extension cable comes with the new screen, and that is most likely faulty with the screen which is probably why touchID is working but not home button click working.
I bet changing to another screen will fix the problem. He can do something about it, replace the home button without touch ID or change to another screen, he's just giving you the run around so that he doesn't have to go through fixing something he screwed up.
해당 답변은 도움이 되었습니까?
점수 4
의견 추가하세요
Sue the repair company for a new phone. If they screwed up, it's not your fault. Sounds like they did something wrong and killed it. If you want to fix it yourself you can do two things;
Sacrifice Touch ID or the home button. You will have to choose one or the other, with a new home button Touch ID will not work but with the home button you have now you can still have Touch ID. Hope this helps! :)
해당 답변은 도움이 되었습니까?
점수 3
의견 추가하세요
First, did you test the phone before you picked it up, and was the home button working? Sucks not having Touch ID but if you buy a aftermarket home button at least your home button will work but you will lose Touch ID. I would talk to the place that did the repair what type of warranty do they offer? Strange the Touch ID works because normally it's the other way around that the Touch ID doesn't work and the home button does.
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
Did or could the company test Touch-ID with original Screen? Probably the "new" Screen..
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
Dakota kiss 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 7
전체 시간: 430
