주요 콘텐츠로 건너뛰기
모델 A1419 / Late 2012 / 2.9 & 3.2 GHz Core i5 또는 3.4 GHz Core i7 프로세서, ID iMac13,2
330 질문 전체 보기
Dead ant inside display
Sound like a joke but is truth. There's a dead ant inside my iMac display. What you recommend my best option to take it off?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 1개
Did you have an image of a sweet looking donut on your display which drove him wild here ;-}
댓글 달기
답변 1개
선택된 답변
Sadly you'll need to replace the display assembly - Big $$$
But! Before you attempt repairing this on your own bring it into an Apple Store or authorized service center.
Technically this should never have happened as the cover glass and the display are fused into a monolithic unit with no means for the ant to get in. Which means it should be covered under an extended warranty.
You might need to push a bit to get it covered and do be careful in transporting your system as you don't want the ant to slide off the visible area of your screen so they see it.
Also make sure your house doesn't have any ants!
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
귀하의 답변을 추가하세요
Ricardo Costa 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 16
전체 시간: 2,192
