Laptop won't turn on unless charger is plugged in
My laptop recently stopped working without the power adapter plugged in. Now, it only turns on if the battery is charging. What can I do to fix this?
좋은 질문 입니까?
취소
The Dell Inspiron 15 (N5050) is a mid-sized laptop manufactured by Dell, Inc. that operates on Windows 7. The laptop features include a WLED HD display screen and a max supported memory of 8 GB.
US$100.00 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
상점 둘러보기Your battery may be dying, or your battery might not be receiving power properly from your power adapter. You might need to consider replacing your battery if the problem continues. You can replace your battery using the following guide: Dell Inspiron N5050 Battery Replacement
Try replacing the battery.
댓글:
Oh hey your back! nice to see you!
Aiden Baker 의 답변
What do you mean 'You're back'? I'm always on. My activity on here depends if I have notifications or not.
(Not really on here much anymore though)
지난 24시간: 25
지난 7일: 149
지난 30일: 537
전체 시간: 8,825
My dell laptop only starts and runs when attached to charger. I thought it was probably the battery so I replaced it with a new one but still have the same problem
john smith 의 답변
so i have a Asus touch screen laptop it wont turn on only if i connect it to the charger
shenika 의 답변
my dell only turns on when it is plugged in (it is refurbished)
gaming master play YT 의 답변
