주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
Model A1238 / 80, 120, or 160 GB hard drive / black or silver metal front
1035 질문 전체 보기
Partial/Broken Display after closing the casing! iPod Classic 120GB
I replaced the battery in my ipod, a check to make sure all was working properly BEFORE closing up the casing revealed all was indeed working correctly.
But after closing the case, the display is now messed up, with part of the image missing and the rest broken into lines with kind of splatter marks across the screen.
Is this just a screen replacement job, a connection problem, or worse?
Any help greatly appreciated!
이 질문에 답하세요 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글:
Thanks. Yes - it looks like I may have squished the LCD on closing the case then.
Nice, fine if you could mark my answer then. =)
의견 추가하세요
답변 2개
가장 유용한 답변
"Splatter marks"?
Sounds like a screen replacement. You probably cracked the LCD..
Google "cracked lcd" and see if your screen looks similar.
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
Hi Rousp
Thought I would just add (for everyone's info) that I received a new screen this morning.
Fitted it, and it works perfectly once again. Your prompt answer saved me a lot of time, I think I've marked your answer correctly, let me know if not.
Thanks
해당 답변은 도움이 되었습니까?
점수 1
댓글:
hi Tony. You should click on "accept answer".
Hi Tony, glad to hear that. As bjoernen dk says you should click on "accept answer"
의견 추가하세요
귀하의 답변을 추가하십시오
Tony 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,243
