주요 콘텐츠로 건너뛰기
2011년 10월 24일 출시 / 2.2, 2.4, 또는 2.5 GHz 쿼드-코어 Intel Core i7 프로세서
399 질문 전체 보기
Heat sinks heat pipe construction.
Hi!
Im refurbishing my old 15" 2011 macbook pro with quad core i7.
Im cleaning and reapplying thermal pastes atm, and I got an strange guestion, I thought you at ifixit are propably the most qualified persons willing to answer this one.
The heatsink has 2 heatpipes which seems to run trough both CPU and GPU contact areas. But I noticed when I stressed my CPU and fiddled with Fan operation, that only the Left side fins (if I remember correctly) got hot, and only left side fan blowed warm air. The right side got warm too, but noticeably less.
What my guestion really is:
Does the both heatpipes connect to both GPU and CPU or is GPU and CPU connected to their own heatpipes?
Just that if they both should have contact with CPU and GPU, my heatsink might have problem with the contact on one of the heatpipes and is better off replaced.
Much appreciated :)
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
선택된 해법
Yes, both heat pipes are connected to each of the heat sinks as you can see here: MacBook Pro Heatsink
And yes yours had a problem! It is fitted with a liquid coolant which has leaked out. You might see some staining on your logic board.
When you get the replacement make sure you don't confuse them ;-} Hint: with a good gram scale you can weigh them the lighter one is the bad one.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
I have the MPB disassembled, and I can see they are at equal length and should make contact to both.. Just cant see how the heatpipes are in contact underneath. But all evidence points to the they should be equally connected to both CPU and GPU. Or it would be really strange decision from engineering point of view. Better just get an replacement sink to be safe.
댓글 달기
귀하의 답변을 추가하세요
Teemu Velin 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 1,067
