주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
Replaced LC/Headphone jack. Callers now unable to hear me clearly.
Hello everyone, just want to say this place is great! Helped me fix my mac a year ago after a beer spilt on it!
On to the iPhone, I have an iPhone 6 that wasn't charging correctly so I replaced the LC/headphone Jack with parts from IFixIt. Charging works great but now callers are unable to hear me clearly at all, some times it just cuts out and other times its scratchy. I tested my voice in the voice recorder and it comes in clear so I'm assuming its the antenna? Ive re connected it multiple times and it hasn't solved my problem. Any help would be great, could it also be a defective new part?
Thanks for your time!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
So after some more investigation people are able to hear me when talking on speaker phone, but when I place the phone to my face like normal they are unable to hear me clearly, it has static and cuts in and out. I also tried a pair of bluetooth headphones and when using those they work clearly for phone calls.
댓글 달기
답변 3개
선택된 답변
Most likely its a defective part, I would recommend getting a new charging port flex and seeing if that works. Also when you test the voice recording is the phone opened or closed? If you are getting clear recording on the microphone when the phone is open but then poor recording when it is closed and your on a call then you may need to clean out the little microphone hole on the bottom of the phone with isopropyl alcohol and/or compressed air.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Thanks for the help! Seems like I fixed it after doing some more research. The hole to the left of the lightning port was clogged with dirt and dust, after fully cleaning it it seems to work fine. Hopefully it last, I find it odd after installing the new part that the dust all of a sudden made it not work correctly. I'll keep everyone updated incase people have the same probablem. Thanks again!
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
It's not the antenna. If you are able to text or use cellular data, the antenna is good. It is likely that the dock flex has a bad mic or installed improperly. Recorder does not use this mic so it is fine.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
zeds 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 67
