주요 콘텐츠로 건너뛰기
High performance tablet computer released by Apple on November 11, 2015. Model A1584.
129 질문 전체 보기
Dead spot in new digitizer. Replaced twice. Dead spots.
Customer brought in an iPad Pro 12.9" with a cracked screen. I replace the screen and soldered the new one on properly 100%. Customer has issues with the dead spot on the screen. So I ordered a brand-new digitizer assembly and install that one. Exact same issue as the first one. Anybody have any suggestions? No apparent damage to the control board and soldering is good. Thanks!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개:
Same supplier? Seconds?
Different Supplier. LCD is good on both.
댓글 달기
답변 2개
then the controller board is bad, simple
Update (11/11/2016)
sounds to me like proccess of elimination its the controller board, too much heat, etc can damage a controller board, hope you find a solution.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
lcd is not ok failure
해당 답변은 도움이 되었습니까?
점수 -2
댓글 1개:
LCD is perfectly fine on both. Ordered from 2 separate manufacturers, dead spot in same exact area.
댓글 달기
귀하의 답변을 추가하세요
GadgetERService 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 469
