주요 콘텐츠로 건너뛰기
A television game console produced by Sony Computer Entertainment, also known as PS4. First announced February 20, 2013 and released November 15, 2013.
1697 질문 전체 보기
Powers on, flashing blue light, sometimes won't power on at all
https://youtu.be/wlKsTbaui5I
I have had my PS4 around 4 years . Dropped it on the ground accidentally moving furniture. Not the first time it's been dropped.
Tried putting washers under the bracket inside the top case, worked for about a week after I attempted this.
Now, sometimes it will power on, then it will either flash the blue light, or it will power to white light , work for a moment but then cut out.
I believe I have it narrowed down to either 1. The HDD and the connection to whatever it goes to is loose and failing, causing it to start sometimes , but then jarring loose or simply vibration from the fan.(I know it sounds somewhat unrealistic)
2. The power supply is not working properly. It clicks on sometimes in the corner internally where the power supply connects to some internal hardware of the ps4. Then shuts off immediately .
I'm not much of a electronics repairman but I have it completely torn apart and wanted some opinions on either buying a new power supply or just buying the new PS4 model coming out?
Thanks
Update (10/10/2016)
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
From what I could find doing research, the blinking blue light on the PS4 indicates a connection issue with the audio/video between the TV and PS4. Have you checked the HDMI port? does it seem loose? Can you show us some pictures of your PS4?
I did find a troubleshooting guide for this problem here on the Playstation community website.
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
I have a video of what's going on . The HDMI port seems ok, and will output video but not audio, now. It was outputting both for a while but kept shutting off after I would play a game for a few minutes . I just played a game for about 15 minutes then it just freezes, makes a screeching noise in my headphone and the PS4 stays powered on but then my tv goes to no signal and I can no longer hear audio through my headphones
I have also tried everything on the PS4. Website troubleshooting guide. As of right now the only thing that seems to work is putting the washers under the bracket inside the PS4 but keeps failing after a few minutes of gameplay
댓글 달기
귀하의 답변을 추가하세요
Blake Hannan 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 4
전체 시간: 190
