주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3530 질문 전체 보기
Odd behaviour from the headphone jack
SO, my headphone jack on an iphone 5s is acting rather strangely:
When i plug a headset/headphones in and listen to music it's absolutely fine, but when someone calls and i pick up, or when i call out then it wont pick up sounds, and im not able to hear the other person, again this is with the headset plugged in, and i've tried 5 different headsets.. Oh and the thinteg drains battery rather fast despites testing a couple of new ones, so everything sort of pointing to a short, i just cant find it.
The device is using IOS 10, if it matters .. But my guess would have to be a bad component on the motherboard.. Anyone encountered this problem before? Because i feel that swapping out the headphone jack assembly is a redundant solution that wont work here I guess..?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
I would try changing the port/headphone assembly as this is probably the easiest/cheapest option.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Hi! does sound play after you take the headphones out? If it doesn't, try cleaning the port with compressed air. You can also take a q-tip, remove the cotton and then push it into the port (not forcefully), you might feel a "click" when you push it in past a certain point. Otherwise I have no sollution.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
salesblock 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 64
