주요 콘텐츠로 건너뛰기
모델 A1297 Unibody: 2009 상반기, 2009 중반기, 2010 중반기, 2011 상반기 & 2011 하반기
544 질문 전체 보기
tip of the headphones jack stuck inside with superglue
Hi i'm in Peru. I have a macbook pro uni-body. The tip of the headphones got stuck inside in my desperation i took it to a pc service and they tried to take the tip pasting it with another piece with super glue, now is dead. There is no sound from the speakers and no option to switch it in the output from headphones to speakers.
1st i wanna know if its possible to change the piece of the headphones in without changing the main board.
2nd i know that switching the output from headphones to speakers is a software thing cause when i start the computer the booonnggg sound came out from the speakers so there must be an option to change from headphones to speakers via software.
thnx for your help
My email rufiansk8@gmail.com
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 1개
Please keep your questions kid-friendly. I edited the swearing out of your post this time because it's a good question. Next time it will be removed. We love the good questions, but it's gotta be clean for everyone.
댓글 달기
답변 2개
가장 유용한 답변
First try hard to remove it using fine pliers if that doesn't work it might be possible to desolder the headphone port from the motherboard and resolder a new one but I don't know where you'd find the jack. This would also be a professional job.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
If it still has plastic on it, you can try lighting a ground wire and put it on the broken piece for a minute or 5 and take it out slowly.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Marco 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 4,193
