What resistors missing in this motherboard MacBook Pro 13" 2011 late
Can i know resistors names ? I want to try to fix my macbook to work normally again. Because both usb not working and camera not working too....
Because after fixing, they are missing now... Seems good repair man was on motherboard....
https://s9.postimg.org/5muh5qcq7/resisto...
Thanks for help and answers
Update (10/21/2016)
After soldering three components back:
C9424 is a 0.47UF 10V 10% capacitor in a 0402 package
R9424 is a 22ohm 1/16W 5% resistor in a 0402 package
R9437 is a 82ohm 1/16W 5% resistor in a 0402 package
MacBook turns on again. But no 5v on MacBook. No iSight camera and usb...
Any suggestion to check ?...
좋은 질문 입니까?
댓글 4개
If you are looking for the resistor size and value, like what you need to replace them with correct one, you will need to buy a schematic. The legality of schematics is still kinda sketchy, apple doesn't want you doing board repair.
echow2001 의
Where i can buy it ? How much it can cost ? Maybe it not worth to repair...
DNABUG 의
dariuspetrusevicius is the image from your board or somewhere else? Logicboard is a 820-2936? the orientation of two components does not look right. They should be horizontal not vertical. Did you resolder those?
oldturkey03 의
Thanks for answers. Yes board is mine. repair main soldered them off and them put them in vertical.... Seems he made mistake and my camera stopped working too. So i need put two in horizontal and one in vertical. But what values they are ?... Because after he starter to repair, camera worked. Just USB not worked.... But after that, 5V gone too with camera....
DNABUG 의
