Apple의 MacBook Pro 노트북 라인은 전문가 및 파워유저를 위한 제품입니다. MacBook Pro 라인은 MacBook Pro 13" Unibody, MacBook Pro 15", MacBook Pro 15" Unibody, MacBook Pro 17" 및 MacBook Pro 17"Unibody를 포함합니다.
15119 질문 전체 보기
How to backup Apple Mail email database automatically?
I am a daily soap user of apple mail which is linked to my Gmail account. I suffered from a very sad case where I lost all my emails due to the server crash. Only 70% of my emails were recovered leaving me even more frustrated. Leaving the past behind, I wanted to make arrangements that this never happens again. Now I am looking for a backup solution that can backup my incoming emails on my hard drive, and more importantly that the solution should automatically backup the email as soon as it is received in the mailbox.
Helpful solutions will be really appreciated. Thanks
해당 질문 답변하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
의견 추가하세요
맥북 배터리 수리 키트
기본 가격은 $69.99
Buy Now
맥북 배터리 수리 키트
기본 가격은 $69.99
Buy Now
3개의 답변
가장 유용한 답변
If you want to fiddle with it - I have not done exactly this, but... - maybe you can use "folder actions": Find your Mail folder in your library, ctrl-click the folder and choose Services at the bottom of the popup, and Folder Actions setup.
I remember I found a script at some point, when I needed an FTP program to automatically upload any NEW doument that arrived in a designated folder.
This is similar. You could save your mail folder by having a folder action copy any changes to the mail folder to your cloud Mail copy folder (allow time for email download to finish, eg when checking your mail in the morning or at email rush hour, otherwise you may end up with copies of half arrived emails. Or you could set the folder action to only upload, when your email program is idle or closed. NB: Email attachments go into a different folder in the Library). Or you could backup to a mounted hard drive folder, or USB stick.
It may not be exactly what you had in mind, funtionality wise, but you will get an instantaneous copy.
Good luck with finding and editing a script. It CAN be done.
And if you find or make a functioning script, please let people know here.
해당 답변은 도움이 되었습니까?
점수 2
의견 추가하세요
Best solution is to export your email database, that way your emails also remain safe and secure. Here's the procedure:
Export mailboxes
Select one or more mailboxes, then choose Mailbox > Export Mailbox.
Choose a folder or create a new folder, then click Choose.
Mail exports the mailboxes as .mbox packages. If you previously exported a mailbox, Mail doesn’t overwrite the existing .mbox file; it creates a new .mbox file, such as My Mailbox 3.mbox.
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
You can also view this forum discussion to how to backup Apple Mail emails database
https://discussions.apple.com/thread/805...
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
Phil Bones 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 1
전체 시간: 119
