주요 콘텐츠로 건너뛰기
모델 A1502 / 2.4, 2.6 또는 2.8 GHz 듀얼-코어 Intel 프로세서 / 2013년 10월 출시
552 질문 전체 보기
No SSD found in recovery mode after liquid spill and clean up
HI
Recently i cleaned my macbook with isopropyl alcohol because i spilled ice tea on it and when i tried to start my macbook again it showed me a flashing folder with a question mark.
After cleaning everything, I keep getting the flashing folder, so i tried the recovery mode, but when i tried to reinstall the OS on my mac he couldn't find my SSD.
I tried a lot to fix it but still nothing... anyone who can help me with this?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Try the SSD in another 2013+ MacBook Air/Retina to eliminate this being the cause. Check the SSD connector for burnt pins. Beyond this, you will need a board view, schematic and soldering skills.
In schematic, find the section about the SSD connector and check the board around the supervisor clkreq circuit for anything burnt. There are also a group of small resistors on the back of the board, on the side opposite the ports, which can easily be damaged by liquid, some responsible for SSD signals.
If it is the board, usually it is a nightmare, have a 2015 one myself I need to get to the bottom of. Make sure the SSD works first, then check out the board afterwards.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Jup that's what I did, and i ended up paying 50€ for a second handed ssd, which is no money compared to what apple services would ask for a repair, thanks for answering!
댓글 달기
귀하의 답변을 추가하세요
baptistetahon 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 945
