메인 콘텐츠로 스킵하기
Repair guides and support for your Samsung TV.
1441 질문 전체 보기
2008 model # LNT5271F
2008 Samsung model # LNT5271F
Ghosting, blurring on right side of TV.
Called Samsung, they say this year does not have a tcon box....
Need advice on what part to order and from where. Thanks
Update (10/18/2016)
Hope you can see it!
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글:
@tweed post an image of what you see with your question. Use this guide Adding images to an existing question for that
의 답변
oldturkey, was this similar symptom to the Samsung junk/failed capacitors on power supply board, that I saw in one of your previous post.
의 답변
의견 추가하세요
1개의 답변
선택된 해법
It is entirely possible that this is related to failed caps on the power board. You will have to remove the back and take a look at the boards. Check for domed or leaking capacitors. Post some images of your boards with your question so we can see what you see. Use this guide for that. Also it looks to me that there is a T-con board. Again take pictures of all the boards and how they are mounted on the inside of your TV
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
귀하의 답변을 추가하십시오
Tweed 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 7
전체 시간: 105
