*#06# won't show imei
when i type *#06# won't show imei
but when i go to settings/about imei is there
i have no service
좋은 질문 입니까?
i have no service
좋은 질문 입니까?
Check your modem firmware. Go to settings,general and about and check if there are numbers there,if no numbers it means firmware is corrupted. First restore your phone and if still problem not solved then you go the hardware way. You'd have to change your base band chip which is a bit difficult.
해당 답변은 도움이 되었습니까?
it's not firmware issue it's hardware
I think the baseband needs to be reballed, this is a common issue. During update or restore do you get error -1? If you do then it definently needs to be reballed.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 4
30일 전: 8
전체 시간: 3,853
i need a answer for this question too . i have more then 5 iphones same issue
r.o0y 의
do you do microsoldering
Adrian Zymeri 의
Pls help me with my iPhone 6 plus Didn't show IMEI number
Oluwaloniglory 의
