이 토론글을 스크롤하여 댓글을 달 적절한 위치를 찾으세요. 그런 다음 "이 게시글에 댓글 달기"를 클릭하여 댓글을 이동하세요.
댓글 1개:
The CB radio is in the 27 MHz band and operates in Amplitude Modulation (AM). I'm not sure what you're attempting to do? Converting the radio to FM in the 27 MHz band will not get you anything useable, besides you just can't switch modulation schemes without changing almost the entire circuitry.
Hendog 의
