주요 콘텐츠로 건너뛰기
A corded, electric, 5 amp spiral saw power tool with a two speed motor by Rotozip. The device comes with a variety of drill bits, sanding and polishing wheels, and a carrying case.
Is it possible to replace the power cord?
I noticed the other day that the power cord on my saw is a little damaged. I don't want to risk using it like this, but the saw is still in good shape so i don't want to throw it away. Is there a way to replace the power cord on the saw?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
선택된 해법
Hey Ezzeddeen,if you're having trouble with your saw check out the troubleshooting page. There is a way to replace the power cord; however, before you go ahead with replacing a part that you are not 100% sure is broken, you can test the cord for connection with a voltmeter. Here is a video that shows you how to test the cord. If you do want to go ahead and replace the cord, we also have a power cord replacement guide.
이 답변이 도움이 되었나요?
점수 3
댓글 달기
@egazali , Yes power tools cord/plug can be changed normally fairly easily by power tool repair tech./electrician or if you want to give it a try google your type of saw power cord replacement. Check the link below to see if replacement cord available or if you will have to have technician make one up. Good luck.
http://www.ereplacementparts.com/
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Ezzeddeen Gazali 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 9
전체 시간: 623
