주요 콘텐츠로 건너뛰기
The Keurig model K70 is a beverage brewing system for home and commercial use. The Keurig is made by the American company Keurig Green Mountain.
26 질문 전체 보기
I keep getting grounds in my coffee, how can I fix it?
Coffee grounds keep showing up in my coffee and I don't know why.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 1개
가장 유용한 답변
It is possible that coffee grounds may have collected in the exit needle of your Keurig. This might result in residual grounds in your drink every time you brew a cup.
https://www.ifixit.com/GuidePDF/link/630...
This guide corresponds to a different keurig, but the process of cleaning the needle is the same. Once you have reached the exit needle component, you can push the end of a paper clip (or similar object) through the exit needle to purge it of any debris.
After the needle is clear and the Keurig is put back together, descale your brewer to rinse everything out.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Dominik Smith 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 7
전체 시간: 885
