Why can’t I connect my Xoom 2 Media Edition to Wifi?
My Wifi is turned on but I am unable to connect to any Wifi network. Why is this?
좋은 질문 입니까?
좋은 질문 입니까?
Try turning it off and then on again. Make sure you login to the wifi you are trying to use if it requires a password. Does wifi work for your other devices? It could be that you have too many devices trying to run off one router. If it won't connect to public wifi like at a coffee shop, it could be your settings are wrong or maybe the antenna inside is messed up. Make sure your setting is set to "always" under "keep wifi on during sleep." If that doesn't improve it, you may want to replace the internal antenna. Hope that helps.
해당 답변은 도움이 되었습니까?
Google SUCK'S::::::::My Paaw
My password should be. "I Hate GOOGLE"!!!!!!!
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 183
