2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4682 질문 전체 보기
iPhone 6 home button question
I have an iPhone 6 that I am replacing the screen on. I used a different screen that has a home button to test the phone and noticed that the phone refuses to boot up with the foreign home button attached. I unplugged it and it tuned on. I plugged it in and the phone shuts off and won't come on until the home button is unplugged. The original home button works fine and the phone will come on when its plugged in. Is this a new feature in iOS 10 and will it affect 3rd part replacement home buttons? (not touch iD function I know that won't work). If its not a new feature then what would cause it to happen?
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글:
are you plugging the home button in after the phone has been powered up?
의 답변
의견 추가하세요
맥북 배터리 수리 키트
기본 가격은 $69.99
Buy Now
맥북 배터리 수리 키트
기본 가격은 $69.99
Buy Now
3개의 답변
선택된 해법
It's supposed to boot with any home button. Make sure you are not plugging or unplugging ribbon / flex cables with the battery plugged in.
Otherwise if you are doing it while it's plugged in, you are probably causing shorts on the logic board which may cause it to shut off. And backlight filter can be blown when unplugging or plugging in the front display cables which results in display but no backlight.
해당 답변은 도움이 되었습니까?
점수 2
의견 추가하세요
가장 유용한 답변
My guess is that the "test" home button you are using has a defect in either the home button itself, or the home button long flat cable that runs under the metal plate.
You can verify by trying that same "test" home button and screen on a different known good phone.
해당 답변은 도움이 되었습니까?
점수 2
의견 추가하세요
i also agree with Ben, and for whether ios 10 affect the 3rd party replacement, here is a blog which shows the experiment results whether ios 10 has an impact on 3rd party iphone replacements.http://www.etradesupply.com/blog/ios-10-...
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
귀하의 답변을 추가하십시오
CAB 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 85
