이 토론글을 스크롤하여 댓글을 달 적절한 위치를 찾으세요. 그런 다음 "이 게시글에 댓글 달기"를 클릭하여 댓글을 이동하세요.
댓글 1개:
Hi,
Does the remote controller screen 'light up' when you turn on the remote i.e. can you see 'backlighting' of screen?
If the backlighting is on then there may be a problem with the video connection to the screen, either a loose cable, a faulty screen or a video circuit fault on the motherboard in the remote.
If the backlighting is not on when you are connected and you can 'see' on a PC so that you know the camera is working, try shining a torch on the remote at an angle very close to the remote screen and see if you can detect a picture. If so it means that the video is OK but the screen backlighting is not.
Hi,
jayeff 의
