Why I have white vertical lines on the screen?
I'm using my ipad then white lines come out of nowhere. I have an image in this link (apple disscusion). Please help
좋은 질문 입니까?
좋은 질문 입니까?
Hi guys, I have had 36 clients approach me with the same problem. I saw no drop damage. Some are even so careful that I believe their iPad mini 2 and 3 never even witnessed a drop let alone a scratch. Bottom line is, I had to replace all their screen, the one underneath the touch glass. SO far none of the clients returned to me for complaints. I believe this is a hardware issue, a design flaw from Apple’s part. I also believe mini’s are plague’d with this white line problem.
해당 답변은 도움이 되었습니까?
I had this happen to my gen1 ipad many years ago. I took a chance and bought a no longer charging ipad gen1 that appeared to have a good screen on ebay. When I replaced the display the issue was fully resolved. I believe it is just the screen going bad sadly.
해당 답변은 도움이 되었습니까?
I also have this on my iPad Mini 2. I have had this iPad for two year now and it had just begun doing this last month. I think I should just get a new one.
해당 답변은 도움이 되었습니까?
I have found that putting the brightness on maximum reduces the chances of this happening. Sometimes I need to turn the screen off and on a few times.
해당 답변은 도움이 되었습니까?
I got rid of mine by having the “battery replaced” by Apple at the Apple Store. In this “repair” the whole device gets replaced with a new device. It solved a bunch of my problems, including a stuck Home button.
해당 답변은 도움이 되었습니까?
24 시간 전: 2
7일 전: 4
30일 전: 14
전체 시간: 9,981
댓글 6개
This just happen to mine too.
I can get it to go away by locking the screen and unlocking, but it will fritz back again.
Mine, unlike yours, seem to keep in a horizontal direction. If I rotate the iPad, the lines rotate as well.
The reboot Apple logo is washed out.
I am really quite unhappy by this.
I wish I had an answer for you. But I don't yet.
I've factory reset the iPad, updated the firmware to 10.1.1, and restored.
It is still doing this.
What happened was that I connected my iPad to the Apple Lightening to HDMI connector with a suspect HDMI cable. I had used my regular HDMI cable the night before and it worked fine, but I found this longer one I had from my parents' place and tried to use it. I think maybe the cord did something to my iPad… maybe.
That's all I got for you. @jetaudiomedia, I hope you can figure this out too.
I "might" still have some extended warranty from my Visa on it, but we are talking mere days left.
SkipR 의
Could you please post the link to your Apple Discussion group thread as well in case someone posts a possible answer/solution there? thx.
SkipR 의
https://discussions.apple.com/thread/773...
SkipR 의
Hi, as I posted on the Apple Discussion page, did you ever come to any resolution for this problem? What ended up being done?
SkipR 의
Did you find a solution for this? I have this too !
Anoud Nadir 의
댓글 1개 더보기
