PowerBook G4 Aluminum 모델에는 여러 가지 유형이 있습니다.
886 질문 전체 보기
What is a HFS volume Problem Mean?
I did an update for an doc.x file shut my computer off and now it will not boot up. I ran the disk utility program on it and it says their is an HFS volume error what does this mean?
Update
How many times should I try this. I have tried two times now and it still hasn't fixed the problem. I am starting to wonder if this has something to do with only having about 1.2 mb left of memory.
Currently I do not want to wipe my disk clean because, I do not have a back up done mostly all pictures. I took the computer into an apple store the tech was able to open my files but he wouldn't save anything unless I bought an eternal hard drive from him $300. I already have a 250mb external hard drive and I will try to load tiger onto it open up my files transfer them over and wipe hard drive clean by rebooting. Apple-Techs suggestion.
Any suggestions on how I can do this using my super drive on the disabled computer or should I do this by using a different mac.
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글:
What is the exact error message?
의 답변
Please post this as an Update to your Question. Only Answers belong here.
의 답변
의견 추가하세요
US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
상점 둘러보기
2개의 답변
선택된 해법
According to the info I find you need to boot into your system disk/ select utilities/ disk repair and run disk repair until it reports no trouble found.
http://support.apple.com/kb/ts1417
해당 답변은 도움이 되었습니까?
점수 4
의견 추가하세요
$300 for an external hard drive is robbery. You can buy a 2 TB drive for $150 or a 500 GB for $60 here: http://www.bestbuy.com
Get the drive and do your backup then reformat your drive. If using 10.5 use Time Machine. 10.4 download SuperDuper and clone the drive: http://www.shirt-pocket.com/SuperDuper/S...
해당 답변은 도움이 되었습니까?
점수 2
댓글:
good answer +
의 답변
의견 추가하세요
귀하의 답변을 추가하십시오
Gideon 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 1
전체 시간: 736
