주요 콘텐츠로 건너뛰기
My tablet can't pwer on
I have problem about huawei tablet
it's can't power on.
I checked the connector and the battery, no problem
what is the problem?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 21
댓글 14개
where to buy an extra board power ic ?
it's can't read the puce
My Huawei t7 cannot power on. I have also press the reset button (volume up+power), but it's not responding. Can I solve it with PC?
my huawei t3 7 can power on but the screen is blank what should i do?
It ask me for a code.
댓글 9개 더보기
댓글 달기
답변 1개
선택된 해법
@mohamedeln , med, Found this info. from searching through forums with similar issue as your huawei tablet t1. Hard reset. Take your sim card and memory card from the tab before the reset, battery is fully charged. Personal data from the tab, contacts, pictures, messages, apps. etc., will be deleted if it was not backed up.
Press and hold volume down key and power key for a while, your screen should turn on with option to enter recovery, follow the prompts to enter recovery mode and set the device to factory defaults. Check the link below for tutoral on reset. Good luck.
https://www.youtube.com/watch?v=7zbLOEN0...
이 답변이 도움이 되었나요?
점수 14
댓글 8개:
My phone doesn't have any network
My tablet says that it still needs more charging, even though it doesnt
How am I supposed to hard reset it if my screen is still black
my photos are not saved in sd card they are saved in tablet, i don't want to delete those
i try all of the ways but nothing works please help me
댓글 3개 더보기
댓글 달기
답변을 추가하세요
med 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 16
지난 30일: 55
전체 시간: 46,426
