주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
My iPhone's screen shows messed up colors
At first my phone's screen stopped responding to my touch momentarily, usually hitting the screen against a flat surface and then turning the screen off and on would fix it. But a few weeks ago I hit it and the colors just like broke. The colors were bars, each bar a different color and only a little tiny corner of the screen would work.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 4
댓글 1개
Thank-you this should help
댓글 달기
답변 2개
선택된 답변
Screen has gone bad. Replacing the front panel will fix the issue.
Guide to replace screen:
iPhone 6 Screen Replacement
You can get the screen from here if you do choose to do it yourself:
iPhone 6 Screen
You have a few options, take it to a mobile phone repair shop to get the screen replaced (I would avoid shopping malls as they are generally either expensive or not very well experienced in mobile phone repairs).
Or you can choose to do it yourself which is fairly simple if you follow the steps in the guide well. Parts that you need to be careful in specifically are the metal plate for the screen connectors on the logic board (phillips head screws are different sizes for a reason), removing the home button, metal plate for front panel which has the home button extension cable together and the front camera requires some delicate prying.
iPhone 6 Screen 이미지
상품
iPhone 6 Screen
$44.99
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
in my settings i have a cpu on or cpu off and when i turn cpu on it shows com.android.systemui and a bunch of numbers and colors example 7.39/in red /7.65 in Green / and 8.08 in Blue does anybody know what that is about ?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
adr123 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 3
전체 시간: 45,933
