주요 콘텐츠로 건너뛰기
4세대 iPhone. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. GSM / 8, 16 또는 32GB 용량 / Model A1332 / 검정 또는 흰색.
2375 질문 전체 보기
Why is iPhone 4 heating up after screen replacement?
I replace iPhone 4G LCD Touch Digitizer Screen and also the phone had some water damage. I took it apart and place all parts in tupperware with rice for 48 hours. After assembling it together it turn on and all functions work but from camera and my concern is the top right side of the phone is heating up a lot it is around the power button and back camera i have no idea where is it coming from. I try to replace the batter and still the same. I also look check the lower antenna connector to make sure is connected right. Any advice?
Thanks!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 2개
What is tapeware?
sorry bushing i meant to say "tupperware with rice" i fix my post. :-)
댓글 달기
답변 2개
가장 유용한 답변
since you had water in it. there is most likely an accumulation of corrosion at some of the connectors on the board. chech for the discoloration on any of the gold colored connectors on the board. once you find it. clean it with alcohol. but very carefully!
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
I had a phone come in the other day that was getting extremely hot and killing batteries. I found that the whoever changed the screen did not properly seat the rear camera and the camera was fire hot. I could not touch it. I removed the camera and cleaned the connector and reassembled the camera and the rest of the phone and it did not heat up again after that. I would also check the dock connector connection to the mainboard depending on where the heat is coming from.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
info 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 6,866
