What's damaged: IO Board, IO cable or both?
After I spilled coffee on my mid-2013 MacBook Air 13 I took everything apart to clean it. Used isopropyl alcohool and distilled water to clean it. The water was necessary to get rid of the sugar.
Put it all back together and everything seems to be working fine. Important bit: plugged my mouse in the IO board USB port and it's working. Speaker works too.
Shut it down to re-arrange the logic board, power it back on, and I try to charge it. It is not charging. MagSafe led doesn't light up. However, while it is not charging, it reports that it is powered from the power adaptor, with the cable plugged in.
The mouse is not working either in that USB port.
But, big surprise: the speaker is working just fine. So is the headphone jack.
I have a vague idea that I rushed to power it on, I probably should have let it dry up a few more days.
My question is this: is the IO board, IO cable or both that are damaged?
PS
I removed the io cable and the fan spins up at full speed. USB cable is obviously not working.
To sum it all up. What is not working are the following:
1. Charging the battery.
2. Left USB port (on IO board).
3. Lid sensor (also on IO board?).
Apple's diagnostics test shows error PPP007 and PPP002.
좋은 질문 입니까?
