주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 5.5” 스크린 iPhone은 iPhone 6의 큰 버전입니다.
1525 질문 전체 보기
Won't ring but work fine to set
I have a phone that I hear all sounds to set them (so not a speaker problem), but the phone doesn't ring or have any notification sounds. Yes, the volume is up, the speaker works, just doesn't ring when calls come in so I miss all calls.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개:
If you look at the top of the screen in the notification bar, if you see a little moon symbol you have do not disturb switch on, to turn off pull up the bottom menu and you'll see the DND symbol hit this to switch off
댓글 달기
답변 1개
Do you know that if you will look carefully above the icon that shows up on your screen when you. Adjust your volume. It has several different volume controls on it depending on when you touch the volume up/down button on the side. Make sure you see where the icon says Ringer, and not volume. Try that.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Becky McCoy 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 4
30일 전: 4
전체 시간: 101
