2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4683 질문 전체 보기
Why does my phone turn off when unplugged from charger?
I have an iPhone 6 that has been repaired once (change of a broken screen and some chip).
It's stuck on 1%and doesn't go any higher.
When I unplug the charger it turns off even if it's been left all night.
It keeps switching on and off.
As long as it's in the charger it works fine.
It doesn't switch on if I plug it in to my computer it keeps showing the apple logo then a black screen on and on.
I at least wanted to back it up in case of a reset.
Sometimes when it switches on it gives 100% but then shuts down quickly even if plugged in.
I get the sign that it's charging but it doesn't increase.
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 8
댓글:
I also have this problem but my phone has never been repaired
의 답변
I think you might have a faulty battery, replace the battery and see if that Fix's your issue.
의 답변
의견 추가하세요
맥북 배터리 수리 키트
기본 가격은 $69.99
Buy Now
맥북 배터리 수리 키트
기본 가격은 $69.99
Buy Now
6개의 답변
선택된 해법
When the Tigris IC detects that there is power from the Lightning port, it allows the USB voltage to power the device instead of the battery. The U2 IC (Tristar) is the one that controls charging. Typically, when an iPhone or iPad exhibits no-charge or fake-charge, it is a Tristar problem.
@migo99 , it would be nice to know what chip exactly was replaced last time. Was it a Touch IC chip or something else? Did you phone work properly after that repair?
Do you have a known-good battery or can you charge your current battery in an other iPhone 6? That would help us eliminate one variable.
Otherwise, based on your comments, it appears to be a charge problem (U2). You need to find a qualified repair shop that does micro-soldering repairs for a proper diagnostic.
해당 답변은 도움이 되었습니까?
점수 5
의견 추가하세요
It seems like it needs a new battery. Any water damage? Do you use an original apple cable or a replica?
해당 답변은 도움이 되었습니까?
점수 2
댓글:
I may be wrong but the charge IC should be fine since it boots up fine connected to usb charger.
의 답변
I think your right, but I'm just trying to get at the reason his battery may be bad. Not entirely sure that can be caused by the bad cables though.
의 답변
No water damage original apple cable. Before this happened it fell though so I'm suspecting that maybe something inside moved.
의 답변
If you had a chip replaced (touch ic?) This may be due to a short caused by this process. How soon after the repair did this start happening?
의 답변
의견 추가하세요
I had this same problem. I was going to go get a new battery but when i added more iCloud storage it started to stay on off the charger. Not sure if i fixed the problem but i haven’t had the problem since.
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
Sounds like a bad charge port. Easy fix. I fix them all the time. I charge $25-35 depending on the iphone.
해당 답변은 도움이 되었습니까?
점수 0
댓글:
hey how much would u charge for an iphone 6 ?
의 답변
How much do you take for iPhone 5
의 답변
의견 추가하세요
I am facing the same problem with my iphone 7 , i have no clue about what to do. Somebody please suggest a solution its just been 3 months
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
definetly a bad battery
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
Migo 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 27
지난 7일: 244
지난 30일: 1,133
전체 시간: 44,152
