Need a diagram of 91 chevy c1500 steering column
Steering wheel is very loose . Took it apart and tightened it up and put back . Wll not go back together. Would like a diagram of steering column.
좋은 질문 입니까?
좋은 질문 입니까?
kpgklm, The links below will show exploded view and vids on steering column to aide in your repair. Check the attached links,instruction and guides, Good luck.
http://www.steeringcolumnservices.com/ex...
해당 답변은 도움이 되었습니까?
L Pfaff came thru with flying colors.. Very fast response with the info I needed. Thank you so much ! Still good people around !
kpgklm, thanks for the response, if it was the answer you needed vote it up, Thanks.
24 시간 전: 0
7일 전: 10
30일 전: 35
전체 시간: 15,422
댓글 1개
Make sure bearing is assembled properly just behind steering wheel
p_buchwald 의
