주요 콘텐츠로 건너뛰기
Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
793 질문 전체 보기
Is it possible to install a bigger HD into an 30gb iPod?
I'd like to know if it's possible to upgrade my iPod's HD once that i'll have to substitute it anyway.
So, I want to know if I can install a 80gb (for example) HD into my old 30gb iPod video (5th generation). In that case, is it possible to upgrade the battery to, or the batery for the 80gb iPod is to big?
Update
Why is necessary to change the headphone jack and de rear panel to?
By the way, i'm sorry for my poor english, but i'm from Brazil
Thanks for your patience!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 4
댓글 1개
Actually, you can also install up to a 256GB SSD, but you have to make sure it is of the 3.3V type, not 5V.
댓글 달기
답변 3개
선택된 답변
Yes, you can upgrade to the 80 GB hard drive. You just need a few other parts also:
60/80 GB Headphone Jack
60/80 GB Battery
80 GB Rear Panel
Rubber Bumpers <---forgot about those the first time through
That is all you need to make the swap.
Update
You must replace the Rear Panel because the 80 GB drive is thicker than the 30 GB and your 30 GB rear panel won't fit over the 80 GB drive. Also, this is the same reason you need the 80 GB headphone jack. It has a longer cable to fit around the thicker 80 GB hard drive. This applies to the battery as well.
iPod Video 60/80 GB Headphone Jack & Hold Switch 이미지
상품
$24.99
iPod Video 60/80 GB Rubber Bumpers 이미지
상품
iPod Video 80 GB Hard Drive 이미지
상품
$48.99
iPod Video 80 GB Rear Panel 이미지
상품
$9.99
iPod Video 60/80 GB Battery 이미지
상품
$13.99
해당 답변은 도움이 되었습니까?
점수 11
댓글 1개:
댓글 달기
You almost got it matt- you forgot the rubber bumpers, those are essential, for a complete list of the parts you need check out this wiki page.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
A fast and easy way to upgrade your iPod's storage is to get an iFlash mSATA adapter and an mSATA SSD of your choice of capacity. I've done this with my iPod Video and now have 128GB of storage available (more to come down the road!)
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Artur Lulai 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 8,043
