What should I do if my battery won't charge?
My battery isn't accepting a charge at all, and the cable is plugged in.
좋은 질문 입니까?
좋은 질문 입니까?
If the device is not charging while the the cable is attached to both a power outlet and the charging port on the device, the battery may be fairly easily replaced by unclipping the old battery from the motherboard and replacing it with a new battery. If this does not solve your problem, you may need to replace the micro-USB port located on the motherboard which requires more work.
해당 답변은 도움이 되었습니까?
24 시간 전: 1
7일 전: 6
30일 전: 8
전체 시간: 741
Student, being worked on by hardworking students
L Pfaff 의
