주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
7.9 inch display iPad Mini, with 16, 32, or 64 GB of storage.
759 질문 전체 보기
What is this (possibly conductive) gray foam adhesive called and where
I have a theory about touch issues that occur after the glass/digitizer replacement on tablets. I believe that the issues are due to the lack of replacement /reapplication of this gray foam tape that is possibly conductive.
However, I have not been able to find this tape/adhesive anywhere. It would help if I knew the name of the product and the maker too? And is this tape conductive? Is anybody else experimented with this stuff? Am I of the correct thinking that this tape may play a role in touch issues following repairs?
I thank the community for their input!
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글:
I'm on my second LCD digitizer and I think the issue is the foam and/or the tape or lack of. With the first LCD digitizer unit, I reapplied the foam I had removed from the original, and everything worked fine until I closed it up, then had all kinds of blank areas on the touch screen. (yes i'm sure the cable wasn't kinked.)
I want to replace the foam instead of reusing the foam. I think it helps the spacing between the parts. where can I find more foam?
의견 추가하세요
Essential Electronics Toolkit
Small Toolkit. Big Possibilities.
Shop Toolkits
Essential
Electronics
Toolkit
Shop Toolkits
답변 1개
선택된 해법
Just insulate the digitiser. New digitisers short out to the metal frame, causing the touch issues. Just insulate the surround of the touch screen with kapton tape (with iPad Airs, I would have to put kapton tape around all edges of the touch screen). This will stop the touch issue. See Digitizer activating itself after digitiser replacement for more details.
Don't know what the grey tape is, but ^ is the best solution to your problem.
해당 답변은 도움이 되었습니까?
점수 2
댓글:
That is great advice. I am taking your advice too! Thank you.
의견 추가하세요
귀하의 답변을 추가하십시오
Ernest Vigil 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 8
전체 시간: 121
