주요 콘텐츠로 건너뛰기
Updated version of the original iPad 2, released in March of 2012 with a smaller die processor and updated internal construction. Repair will require the use of heat and careful prying.
73 질문 전체 보기
adhesive won't stick on new cable
I bought new volume cable but can't get the adhesive to stick. Any Advice?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
Replace the existing adhesive on the housing or volume button cable itself with new adhesive?
I know that Tesa / Red transparent double sided tape works well for this.
댓글 달기
답변 2개
선택된 답변
It kind of depends on what part of the cable. For most of it, red tape is fine. The part that always gives me problems is where it goes from volume to power and is on top of the frame. I use yellow tape for that part. If the volume buttons are giving you trouble, cut out tiny little pieces of red tape.
I'm pretty sure all of those volume flexes were made when Reagan was in office. The adhesive is always messed up on them when I go to use them.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Yes the tesa tape would work with this repair.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Brandon Ballington 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 104
