주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
eMac은 교육 시장용으로 설계된 올인원 G4-기반 Mac입니다. CRT 화면을 사용하는 마지막 Mac이었으며 학교 및 기타 기관에 저렴한 가격으로 판매되었습니다.
eMac won't boot either
Emac will not boot after last software update. Will not boot from hard drive or disk. Three things happen. First, I get a kernal panic and freeze after a few seconds, or the computer shuts down. or the spining indicator goes on indefinitely. On rare occasions, I get the symbol for OS not found. I have reset the PRAM and I get both bongs. Any ideas?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 1개
Thanks for suggestions, but nothing worked to boot the machine. I do not know if we are facing a bad hard disk or mother board. If it was a hard disk, I assume I should have been able to boot from the install disk. So I fear it's a mother board. Until next time....Adios
댓글 달기
답변 2개
선택된 해법
Boot from your system installation disk by inserting the disk and starting up holding down the "C" key. Go to the second screen pull down menu to Utilities -> Disk utility and repir the hard drive till it runs clear. Then try restarting.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
agreed +
댓글 달기
Sounds like one of the updates failed. If you still have the install disks, you can reinstall the operating system and select the option to save all of the old files in a folder called "Previous System" If you want to keep them, and have inportant info that you want to keep. Short of that, there is no way to really fix this.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
professor 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 4
전체 시간: 1,264
