Vertical color lines appear when turned on
Multi colored vertical lines appear when TV is turned on - they disappeared after a few minutes but now remain constant
좋은 질문 입니까?
좋은 질문 입니까?
Gerald Herd could be caused by corroded or loose ribbon cables as well as loose TAB's. Of course it can also be the T-con board. Post some images of what your screen looks like with your question. For that use this guide. It will allow us to see what you see. Also, it helps if you can tell us what you have checked thus far.
해당 답변은 도움이 되었습니까?
Hi I have coloured lines centre of tv which are vertical
unplugged ribbon cables and put pressure on the cables going into screen
Lines are constant and go over picture on screen and menu bar
lines won’t change get smaller or disappear
many help would be much appreciated
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 3,306
댓글 4개
I am having the same issue. And its getting worse. What can I do to fix this?
Benjamin Loree 의
@starkwolf30 what have you checked? Same TV as the OP? did you check what was listed in my original answer?
oldturkey03 의
I have the same problem.
Juanita 의
it might be a bad T-Con board
Adrion Taylor 의
