주요 콘텐츠로 건너뛰기
How to upgrade the M.2 SSD
Dear ifixit team,
I have an HP Spectre X2 Detacheable 12 inch tablet. However, the unit comes with a 128GB M.2 2280 ssd. Does anybody know on how to open the unit in order to replace this ssd with a larger capacity? Thank you so much for your answers. Regards Surfix007
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 7
댓글 달기
답변 3개
가장 유용한 답변
Here is the "end of life" recycling guide that shows some basics on how to take the spectre x2 apart. Would be a good place to start on a project like replacing the SSD.
http://h22235.www2.hp.com/hpinfo/globalc...
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
I have HP Spectre X2 12-a009nr. Theres no 4 screws like in the link that you provided :(
I think you need to follow this guide: http://h22235.www2.hp.com/hpinfo/globalc... . If so then I won't touch it as it is glued together.
If, however, you have found a solution please let me know as I would also be interested to know
댓글 달기
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
you can open the machine without removing the screen from the bezel.. use a spudger between the black plastic bezel and metal frame. It will pop off easily, and reinstall with no glue. I take mine apart for fun. the drive is a standard m.2 sata ssd
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Start in the upper right corner near the power button.
댓글 달기
귀하의 답변을 추가하세요
Rainer Michelis 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 2,314
