주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
Why Does my Reception Keep Dropping Out after Refurb of Chassis
Hello all,
I am posting to ask why the reception in my refurbished iphone 6 keeps dropping out?
The iphone had the entire chassis replaced as the old one was too badly bent & damaged.
Is it possible the after market chassis+parts are to blame for the reception errors?
Or is it possible from the previous drop, the reception components on the logic board broke? Would the either work 100% or not at all?
Any help is appreciated , thanks!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 3개:
Maybe from the dropping. Did you changed the housing? Maybe one of the antennas plugs is not connected or not seated connected.
I changed the housing to a non-OEM housing, it had signal issues. I switched to an OEM housing, it still has signal issues. I think its to do with the logic board. Is it fixable ? ;(
There is most likely a missing antenna screw that connects to the housing. OR you need a new dock connector OR- now im not 100% sure about this but - maybe a ground connection to the dock connector? Can someone correct me if the last statement is completely wrong?
댓글 달기
답변 3개
Your iPhone 6 housing actually acts as an antenna. It's designed in a way to work perfectly with the design of the board itself. Having an aftermarket housing can easily reduce signal strength.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Ive replaced many housings.... I have never had this issue.... It IS possible, but I'm gonna say not as likely as a bad transplant
댓글 달기
There is most likely a missing antenna screw that connects to the housing. OR you need a new dock connector OR- now I'm not 100% sure about this but - maybe a ground connection to the dock connector? Can someone correct me if the last statement is completely wrong?
Asumming the antenna cable is connected and is not faulty itsself
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
All screws are in the right place. and I even moved the logic board back over to an OEM chassis/parts which still give the same effect. So I believe the damage is done from the drop. WHO SPECIALISES IN LOGIC BOARD REPAIR?!
댓글 달기
Check this flex to be correctly connected and the copper field clear.
https://d3nevzfk7ii3be.cloudfront.net/ig...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
ZsTech 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 61
