Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3835 질문 전체 보기
still no lcd even if replaced lcd
hello people, i have an iphone 5s, wich still have no lcd after battery and screen replacement, its frustating, tried restore and hard reset, rereplacing etc., but nothings happend to get my lcd signal back. Again replaced screen with second brand new one but still the same problem.
해당 질문 답변하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글:
First i want to ask to you all,
i have a small screw hole ring with a very small and thin cable on it, at the top upper inside middle my iphone, where this must been connected to? and will it help getting back lcd if i add the metal plate on the backside of the screen and remove the red plastic sheet, or goes the signal really only over the lcd flat cable?? also, i've read here somewhere that someone has pulling all metal lips a bit little op and say it worked. This all 3 questions, will this work getting back my lcd signal?
의 답변
Have bought an iPhone 5c but want this getting to work. So anybody know something wat i can try?
의 답변
의견 추가하세요
US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
상점 둘러보기
1개의 답변
You need to first determine if the phone wont turn on or the screen wont turn on. Plug it into itunes and if it connects you have a lcd problem, if it says your in recovery mode you may be stuck in DFU mode, holding the power & home button for 10-15secs will reboot your phone. If the phone wont do anything you either have a bad battery or you have damaged something when you changed the screen.
That little metal thing wont stop the lcd from tuning on and bending the lcd tabs wont do anything either.
해당 답변은 도움이 되었습니까?
점수 0
댓글:
i think it's a bad backlight chip at motherboard. if i look really close to the screen the phone works
의 답변
의견 추가하세요
귀하의 답변을 추가하십시오
Michel 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 62
