주요 콘텐츠로 건너뛰기
첫 번째 iPhone 모델, Model A1203은 4, 8, 또는 16GB 용량과 알루미늄 뒷면을 가지고 있습니다. 수리를 하려면 상당한 양의 비집기와 납땜을 요구할 수 있습니다.
224 질문 전체 보기
No voices, just sound while listening to music
Hi!
When I listen to music with my iPhone i just hear the sound. There are voices but very quiet. It's not the fault of the earphones, I changed them. And I can't remember any accident or something to be the reason for this..
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 2개
which iphone do you have?
It's the 2G..
댓글 달기
답변 2개
선택된 답변
If you normally keep it in your pocket, I suggest checking the jack for lint buildup. I have an iPhone 3G, myself, and once I got the lint out (straightened paperclip and compressed air), the problems went away! It's so simple, I had kicked myself for never thinking of it as it had been bugging me for months!
It's really amazing to think that there was so much lint in there that it was pushing the plug out of alignment...but there it was.
If this, by chance, doesn't solve the problem, it may be a short or fault in the jack or it's wiring. However, that's rather unlikely. The i-series mobile devices, regardless of generation, are pretty solidly built.
I hope this helps!
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Good answer.
댓글 달기
i thinks its the earphones actually because i had the same problem....they have to be a certain size for the iphone or youll have that problem....
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
No it's not their fault.. I've got the original Apple earphones and with my iPod, they work without any problems. Then I tried other earphones which fit into the iPhone, but there are the same problems again..
댓글 달기
귀하의 답변을 추가하세요
Svenja 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 14,206
