Error Code B0238 on Chevrolet Impala
How do I fix Chevrolet Impala 2006, 3.5L engine, that is getting the error code
B0238?
좋은 질문 입니까?
B0238?
좋은 질문 입니까?
@jeffwashington , Jeff, Are you experiencing any problems as far as heat/defrost blower vent direction if not, record code for future reference and erase.
If you are having a problem, one of the mode actuators could be sticking/faulty, the dealer would have to hook up their Advanced scanner to locate and diagnose precise fault, bad wire/plug, control module, faulty/sticking actuator.
DTC B0238 Air flow control #1 (defrost) circuit malfunction
DTC B0238 Mode Door Circuit Range the door air-mix actuator
Below are a few links to read through, sounds like these actuators fail often, last link tells of a reset procedure you may want to try. Good luck.
http://www.gmforum.com/2000-2005-90/hvac...
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 162
