주요 콘텐츠로 건너뛰기
The Chevrolet Cruze is a compact car made by the Chevrolet division of General Motors. The Cruze was first released in 2008 with a front-engine, front-wheel-drive layout.
32 질문 전체 보기
Why is my car not starting and showing code 89
My 2012 chevrolet cruze is giving problem to start as if my battery if flat bt all the lights and hooter are working properly.When i turn the key the alternator turns a little bit and gives me code 89.When i jump start the car it starts without any problem.my battery was serviced and the car could start atleast 4 times after that but then it started with the problem the next day
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 2개
I also have similar problem.
Error code 89, sound is loud.
What could be the problem?
Yes, similar the noice of the engine become in side the sound system...through the speakers.
댓글 달기
답변 2개
가장 유용한 답변
Hi,
Check the output from the alternator.
Use a DMM (Digital Multimeter _ Voltmeter function) and connect it across the battery terminals with the engine running, (Be careful when you do this as the engine is running!)
The Voltmeter should read between 13.8-14.4V DC. If it is less than 13.8V DC then the alternator is not charging the battery and it will slowly go flat.
If this is the case take your car to an auto electrician to get the alternator checked.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
This some how related to the steeeing lock, shutdown the car and press the start button without break (or open the contact if its not with a keyless start) and then unlock the steering then move a lttle left or right the start the car it will start normaly.. If it works dont ask me why coz I dont know, I just discover this solution by myself
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Thermostat issues
댓글 달기
귀하의 답변을 추가하세요
Joseph cafu 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 24
30일 전: 68
전체 시간: 45,962
