주요 콘텐츠로 건너뛰기
모델 번호 A1238 / 80, 120, 또는160GB 하드 드라이브 / 검정색 또는 은색 금속 외형
904 질문 전체 보기
replaced battery and momentarily turned on then died
I replaced the battery with one I bought from you guys - it worked then died and now won't do anything- it may be possible that my charging cable is worn out but wonder if there is some other troubleshhot I could try - I think I was using a cheaper version of the charger usb cable or one for my iphone but not sure if that was the problem. It is the original upod usb cable that I think is too frayed and that might be it?
ideas?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
선택된 답변
To rule out the charger cable, see if you can borrow one that's known to work from a friend (or check if yours is working on a friends iPod). If it still won't charge try to reconnect the battery (did you use the locking mechanism on the connector correctly?).
If that doesn't help, then three things come to mind as possible causes: the battery, the ribbon cable or the connector/logicboard.
It seems unlikely that the battery is the problem, but it can be examined using some kind of meter, that I don't know about. If the ribbon cable has been damaged, it's most likely to be where it's bend. But my guess is that if reconnecting the battery doesn't help, then something has caused malfunction either in the connector the logic board. As you changed the battery you could have touched a component or something else might have happened, that would cause corrosion leading to malfunction after some use.
It might be something that can be fixed by a cleaning. Or has something happened to your iPod, like a liquid spill?
good luck and please update on progress
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
blalocks 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 833
