주요 콘텐츠로 건너뛰기
A 7" tablet with a Android 4.2 (Jelly Bean) operating system.
31 질문 전체 보기
How do I unlock my tablet, can't remember the pin I used
i can't unlock my tablet or reset it. it won't let me leave the lock screen
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 8
댓글 달기
답변 5개
가장 유용한 답변
On the RCA tablets if you cant remember your password and have to do a hard reset on it you power it off first then when you go to turn it back on hold the power button and volume up button at the same time. When the picture of the dogs come on the screen hold the power and volume up button for 2 seconds and release. After the screen loads you should get the android on the screen and it should say no command at this point hold the volume up button for 5 seconds then a menu will come up allowing you to wipe and reset the tablet. Hope this helps
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
What if it don't work
댓글 달기
I forgot my pin screen is locked. How do I get into my tablet
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
No Android setting lock battery disconnect after 3 hrs did nothi b g still locked rca code 0530 does nothing any help would be appreciated I'm just gonna take the 10lb sleg to it trying for days to unlock it .,
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I have the exact same problem
댓글 달기
J’ai oublié mon mot de passe pour débarrer ma tablette …….que faire…
RCA 8 Appollo
J’aimerais avoir une réponse en français svp
Johanne Vallée
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
How do I unlock my Proscan with a pattern
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Joan Peterson 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 10
전체 시간: 9,004
